Originally Posted by
krokodyl
Ok thanks, one more thing, should the fly wheel be touching the wheel with teeth thing? Yes i am a newb and dont know what that part is called. Anyways it seems the the flywhhel has to be firced agains that part so that the both spin.
If the flywheel rubs on the clutchbell, that's bad. You would want to shim the clutchbell out a little bit if that's the case. A picture would help confirm this.
