Another project, another poll....
Based on the full size story of that flew air reconnaissance over Berlin
https://youtu.be/ie3SrjLlcUY
I decided to produce a true scale Spit for the detailed minded.
This time I would like to get a consensus for the preferred choice of wing assembly.
The full size Spitfire Mk VIII, IX and XI had a wingspan of 36 ft 10 in (11.23 m) at 1/5 scale it will make a 88.4" / 2.24m wingspan
Options: Two piece wing with a ply joiner or a 3 piece wing with tubes outside the landing gear. This option will probably add extra weight.
The wing will be built up and sheeted with .3/32 skins and the stabilizer with 1/16th skin.
The fuselage has been started and will be 3 piece fiberglass with all the panel lines and screws molded in:
full cowl, fuselage, tail. It will save the builder 6 months of work and headaches with all the complex shapes involved in this airplane.
Thanks for the input.
JG
