RCU Forums - View Single Post - caldera 3.0 engine upgrade.
Old 11-04-2015 | 03:21 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
There should be a tapered collet that goes onto the crankshaft that locks the flywheel to the shaft when the flywheel nut is tightened. If you removed the collet and put the flywheel on alone, it will rub on the crankcase and also not be centered when you tighten the nut.
