RCU Forums - View Single Post - Meister scale P-47 D-25 Diary of a scale build
Thread
11-07-2015, 03:26 PM
94
TonyBuilder
My Feedback: (
11
1 Post
Been working on the elevators.
I added some balsa to the TE to build it up as I will be trying something new.
I never liked the thick fat TE on the surfaces, dead giveaway that it tis a model.
So I am using some thin G-10 that will get glued into the TE between the top and bottom skins.
Also the ribs are all of and different sizes so I need to add some balsa and get them all the same.
Once the TE fir was added I put the two halves together and sanded them so they would both be the same shape.
Next I sanded the added fir so it tapered to the bottom skin (1/16"). The fir was 1/8"
Once the fir was shaped I had to reses it to accommodate the G-10
I cut the G-10 and cut the trim tab into it
The G-10 glued in and the ribs all lined up as I fired them too.
The blocks are for the hinges and the one at the inner part is for a dowel to pin the torque rod to.
I held them back about 5/8" as I will be cutting 3/4 off for the new LE.
Top skin is now glued on and I joined the two halves together with tape so I could sand them equal.
You can see how the ribs are off in size and I should have checked them before I skinned them, but I used 3/32" balsa on the top so I could sand it to fit the stab.
I wont sand the TE until the ends are put on.
I cut the old LD off and sanded them equal.
I first glue in a 3/32" balsa to face the elevator. Then a 1/4" balsa followed by a 1/2" balsa to bring the elevator up to size.
This will give me some sanding room on the TE.
With the ends squared up and sanded I can add the ends.
Ends and tips all glued in. I wont sand them until the stab is ready to sand.
TB
03:51 PM
Reply
Like
TonyBuilder
View Public Profile
Send a private message to TonyBuilder
Find More Posts by TonyBuilder
View iTrader Profile
