RCU Forums - View Single Post - ATJ Turbines
Thread: ATJ Turbines
Old 11-09-2015 | 03:30 AM
  #128
josephfly
2015 all new version ATJ220SV , 22kg thrust turbine jet engine it's super value engine in the world .
This is all new design turbine , all different then old Ti series The new type V3 burner long life and fast ignition
EGT sensor , fuel and burner valve Inside the engine front cover , one FASTO fitting for fuel inlet engine.
full Inconel 600 material combustion chamber long life over 300hr , engine major parts turbine wheel and NGV use Inconel 713 material ,
Diffuser , intake , upper cover , engine case .. etc made by T6061 aviation level aluminum rod bar all use CNC machine to finish product ,
long life starter motor low working temperature We also keep aluminum starter case not use plastic starter case ,
Xicoy V10 kerostart ECU and GSU easy to use .
ATJ220SV Turbine engine Specifications
Dimensions : Outer Diameter 112mm; Length: 293mm
Weight : 1760grams (including starter)
Maximum thrust : 22KG @ 123,000rpm
Idle RPM : 35,000 Idle thrust @ 35,000 : 0.85KG
EGT : 430 - 630 degree C ,
Fuel Consumption : @ max rpm 650 gms/min ,
Fuel/ oil : Jet fuel or Kerosene or Diesel + 5% oil (synthetic turbine engine oil)
ID:	2129803   Click image for larger version
