Dave, the cortex can take the s.bus info from one wire? Or, do you have to have an encoder in-between the two? I have the gyro and cortex, never tried to make them play with sbus. You are going to have to use matchboxes or Y-leads and mechanically adjust on this plane, that would blow. I'd rather do without the gyro.
Hello Futaba…. Can we please have an s.bus rx with a built in 3-axis gyro and full assignability of channels with the tx???? I can do it with the power box royal SRS, but that is way overkill for most planes.
