Guys.. for now if you are using REX, repeat a REX UDI or EX Bus with NON-Jeti equipment, such as heli controller equipment with a REX receiver.. Repeat REX receiver only, some third party UDI interfaces have had trouble with the "non release back to back packets on the bus", decreasing beyond their limits when using a REX receiver as primary and any jeti receivers in dual path. Its the faster receiver.
Jeti has replicated this on some Heli controllers and is working on it. The Pre-Rex receivers work fine in this application.. The UDI/EXb speed of the Rex is always in Auto, vice the standard receiver being able to set the UDI/EXb speed.
This DOES NOT affect the any Jeti to Jeti interfaces, such as Central Boxes or Jeti to Jeti equipment, and it does not affect the Pre-Rex receivers..
They are recommending not flying your Heli with UDi or EXbus at the moment until its verified or addressed.. some Heli's have updated their controller SW already..
Im one of the Team Jeti USA for Jeti only, so I don't want to get into details nor speak for ZB, but you are perfectly safe flying your CB100/200/R3,4,5,6,7,9,11,14,18 in Dual path or Default.. ZB is in constant communication with Jeti on this because he has a large Heli ownership group.
If you have a REX receiver and another receiver in the plane with servos plugged into it, you are also ok.. Its specifically addressed in the UDI/EXb interface to third party controllers
More to follow.. You can check the other forums for additional details..
