Originally Posted by
Snaprollman
Why disappear telemetry from Xicoy on Jetibox emulator for about 1-2 minutes while after I've activated it? Must enter to reactivate eg after landing.Is it something with the setup I did not realize?
If you are actually using the Jetibox emulator to look at the Xicoy ECU telemetry adapter there is an easier way. Instead, simply allow the DS16 enough time to discover the Xicoy device and then use the Displayed Telemetry menu to ADD the telemetry items you wish to monitor (RPM, EGT, etc) directly to the main display. You really don't need to use the Jetiboix emulator with the Xicoy ECU telemetry adapter.
Wayne
