Guys, What are you putting on the main page of your PRofi? I haven't really messed with profi a lot, but now with the FC-1 Im setting it up for my caller on a maiden.. Obviously the RPM/EGT/Fuel.. ideas?
Separately, the FC1 by Gaspar, builds in the telemetry module he makes with a lot of other functions if anyone hasn't checked it out.. It is compatible with ALL Xicoy based ECU's regardless of turbine. He has one for Jetcat too. It has airspeed module and GPS module options.. Check it out..
http://www.xicoy.com/catalog/index.p...x.php?cPath=54
It replaces the ground unit, and is designed to be installed. It will also allow menu access on board and with the transmitter..
