Randy, just a 3mm threaded rod is all that comes with the kit. The mains will need to have two small holes drilled and tapped, then I will use a 3mm screw/nut to hold the gear door at the height I need. They dont have pre drilled holes for a door.
The the tail section field removable works the same way skymaster does their wing stores, a hole is cut put the head of the bolt in then a thin channel is cut for the bolt to slide down in and then you have a a couple installed plates that locks the tail section on the top and bottom. I will go over these in my next video to help clear up things for people.
Matt I will put a nut on the metal clevises, just didnt do that yet. I think thats what your referring to.
