RCU Forums - View Single Post - reed valves
Thread: reed valves
Old 11-15-2015 | 11:12 AM
Truckracer
My Feedback: (19)
Originally Posted by av8tor1977
For an all out, max effort engine, reed valves can limit intake flow, and thus limit max rpm's and power.
AV8TOR
Not only limiting flow but above certain speeds, they simply can't move fast enough to properly meter the intake airflow. Reed flutter and resonance come into play followed shortly thereafter by reed destruction.
I always though of a reed valve engine as one that exhibits a better low and mid-range torque curve than a piston ported engine. A piston ported engine seems to breath much better in the high RPM ranges and if ported correctly and provided with a proper fuel, air and ignition source can easily rev to the point of mechanical destruction. A reed valve engine will just sort of level off in the high RPM ranges as the reeds become inefficient .... kind of like valve float in a 4 stroke engine where an engine only rev's so high and then it just stops turning any faster. Of course there are exceptions to all of these generalizations.
