You make some good points about cleanup, when not using the crosslinker.
I paint my color in a single day, so it's not an issue for me.
Painting the color in a single day increases adhesion between coats. You get a chemical bond. By painting a single coat, and waiting, sanding does become necessary, This is because you now are creating a mechanical bond, which is less desirable.
