RCU Forums - View Single Post - what engine is this exactly?
Old 11-17-2015 | 10:21 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Originally Posted by grabbem88
Took it apart...pretty simple and basic 2 stroke concept...
No scoring or groove wear.
But it was wet around 1 way that gasket and silicone was flakey and wet brittle too
Which gasket?
Now on the crankshaft there is a groove towards flywheel is there supposed to be a o ring There?
No.
Carb o rings look bad as well
So I think I had some major air leaks and running pig rich was the only way to get it running
I might be wrong but it's worth a try to reseal it and try again
Also the bottom screw under Hsn how do I reset it?
From what I have found, that midrange screw is set so the head of the screw is flush with the outside of the carb body. Roughly 3-3 1/4 turns from seated.
And could this carb be suspect as well
I haven't used a 3-needle carb, but I would guess they work as well as a 2-needle carb. Most folks that just bash never adjust the midrange needle (which is really the seat for the throttle valve and low speed needle).
