RCU Forums - View Single Post - Galeb G2 - new jet made in Serbia
Thread
11-18-2015, 01:26 PM
281
mirce
OK, as I wrote last time, I made and glued wing saddle on fuselage. This parts was made from 1,5 mm thin balsa, but later will come layer of glass cloth...
Hardwood plates for wing bolts was glued few weeks ago, so next step was to made holes for wing fixing bolts.
Finally I can turn around bigger G2 and set it on retracts...
Next step was to put and stick horizontal stabilizer. After measures that operation was done...
All was done same like on smaller Galeb, so I wasn't made pictures again of this process.
Rudder is same story like on 1/5 scale G2, only difference was that here I use plywood parts for servo mount. That system is same like on flaps or ailerons...
Than sanding and sanding and sanding rudder leading edge ...
Next day, other rudder side...
But, result was...
Reply
Like
mirce
View Public Profile
Send a private message to mirce
Find More Posts by mirce
View iTrader Profile
