RCU Forums - View Single Post - lanier cap 232 arf-hard points in wing
Old 05-01-2002 | 11:51 PM
3dkid
Default lanier cap 232 arf-hard points in wing
if you use the rudder servo on pull pull cable's right under the canopy then you can move the RX battery aroung where you want it i have the ignition battery right under the engine box along with the ignition battery i could possibly get come pics for you if i can i will post them on here well good luck with the cap!
David
