Hello Nick, no I did not, I have one very faint side view drawing is all. My model was started by a very good builder and finished by an arf foamy guy, no building experience at all. I bought it and did the best I couuld with using the pre-soldered center cabane incidence angles and some down in the motor mount. Did not fly well, climbed with anything much past 1/4 throttle. I believe the stab incidence is way off, if I remeber right it is about 5.5 degrees leading edge down. I am about midway thru on a Byron Corsair build and when that is done I will remove the stab and reset at 0 deg. The airplane is about useless as it is, but very pretty in the air, John.
