RCU Forums - View Single Post - Tamiya recoil problem help needed
Old 11-30-2015 | 08:49 PM
TheBennyB
Also check the nut on the bottom of the unit that holds the main plastic gear that rotates and moves the barrel. It will come loose and the gear will wobble and bind. Just tighten it and put a dab of thread lock to hold it place. I've had it happen to where the nut came completely off and had to go searching in the lower hull for it.
