Thank you Mike Fish...
I take down all control surface and apply acrylic filler...
Surface are very good, almost that I don't need to do this operation, but...
Few days ago I got thrust tubes from Germany, from IQ Hammer. Quality is very well...
On bigger G2 putting thrust tube in fuselage was done without any problem...
... but on smaller model tube can't fit inside...
Rear fuselage side is narrow, so no space for some "operation" to made it wider.
I call IQ Hammer and ask Dietmar what can we do now. I told him many times that exhaust tube can't be wider than 95mm. They made it 95mm at rear tube side, but in front, because cone, tube is wider...
My question was if I send this tube back, will they made me new one. Answer was to not sent tube, that is gift for me, they will made me new in right dimension and sent it to me for free!!!
Thank you IQ Hammer...
Last work on fuselage was work on fuselage wing transition...
After that I can start with applying filler on fuselage and wing also...
Nice day few days ago, I used for sanding. Ailerons was my violin...
With this "music" I greet you from Senta, Serbia
