RCU Forums - View Single Post - How to Add Nose Weight, Chime In!
Old 12-02-2015 | 06:40 AM
ahicks
I'm likely on the anal side when it comes to adding weight. Maybe you've done it already, but I would spend some time figuring a way around the tail mounted servos. Possibly going with a single (center mounted?) pull-pull setup?
Just a few ounces back that far can cost you several times that amount in weight required to balance them up front.
