RCU Forums - View Single Post - How to Add Nose Weight, Chime In!
Old 12-02-2015 | 12:01 PM
combatpigg's Avatar
combatpigg
I wonder if you could add a spacer between the engine and the firewall..?
If the distance from the CG to the tail is 2 or 3 times the distance you have from the CG to the prop, you can see how much help shifting weight forward is.
I don't think using those "Heavy Prop Hubs" is good for the engine long term, but in some cases they might make sense.
