Originally Posted by
Dave Wilshere
Cooler tailpipe temps with larger diameter...
The biggy is static thrust, most models (scale) are over powered for most people's throttle use! For a sports jet there is an optimum, for scale run as large as practical and its usually right.
142-180 motors can share a pipe, 90mm is my go to size, 92-95mm 180. 100mm 200 big block
Most people set the tailcone to tailpipe distance wrong and this affects thrust more!
Besides being the general rule 25mm for most tailcone to tailpipe what is the correct distance?
