RCU Forums - View Single Post - Help: No rudder control when speed control on props active?
Old 12-06-2015 | 09:45 AM
bensid54's Avatar
bensid54
The only thing I can think of is the RX is your problem, check the wiring pins make sure the grounds and signal wires are correct and maybe try another RX to see if that could be the problem. Also make sure the servos and speed controls have only one power source for control that in itself could be your problem.
