The snuffler is a great field saving muffler!
I have a loose component on one of my Snufflers and I'm not sure where to tighten, or if tightening is necessary.
First picture is a typical install on one of my Giant Stingers. I added a safety strap so I don't lose the 1 lb. muffler due to vibration. I also use plenty of loc tite. The second picture show the Snuffler I'm having a problem with. This muffler has over 50 flights on it and "Part B" on both left and right side is rotating loose, but has not come off yet. The nut on "screw A" has been tighten as far as it can without snapping it. "Part B" still rotates, Part A is secure. What do I need to do the make sure part b does not rotate, or is this condition OK? Hard to see on the inside because its blackened.
