I the bore is the same and the ring thickness is the same, I see no reason why it wouldn't. If the bore is larger (longer ring) in the magnum by a small amount, you can file the end of the ring to make it fit the smaller bore. You would need to test fit the new ring in the bore (not on the piston) and ensure it doesn't bind anywhere in the liner anyway.
