Originally Posted by
carlgrover
I only had ailerons on the bottom wing. I never felt it was necessary to have them on the top wing. If you do put ailerons on that wing it will require quite a bit of mods to make it work.
Carl
or 6 channel RX to mix upper and lower aileron servos on. It's like the Biper Cub I am building, Deciding on whether to lock the lower ailerons or add 2 more servos to the bottom wing and mix channels on the RX. If the radio can be setup to do so, can turn the bottom wing into flaperons, and do some hang time.
