RCU Forums - View Single Post - Gas to glo plug.
Old 12-07-2015 | 10:59 PM
bcchi
Originally Posted by bcchi
I have not had time to try the gasket thing yet,but cannot change port timing much,might make it better.Got more bench run time on the Valley View 20.It seems to do real well. do not no about other glo plugs but have several I am going to try.
BCCHI
Could not change compression much with gasket on adapter.You need the glo coil down in the combustion chamber as far as you can get it.Will run on O>S four stroke plug but idle is crappy.I do not use a gasket on the adapter at all.
BCCHI
