Originally Posted by
zemanski99
This is the first time I heard that you balance with nose down angle. I have all my models balanced with fuse level. Could this be my problem then ??? best Jan
Level is the best way. It tells you where the CG really is.
Nose down... Tells you only one thing for sure. The CG is somewhere forward. How much is a guess. Why guess?
Balancing level is NOT your problem. In fact, if balance was your problem how have you gotten so many good flights and suddenly a bad one?
