RE: Annoying things that happen while building an ARF
Most directions with ARF's state that you should trial fit. I use a #11 exacto blade to clear and clean out the hinge slots. Even the wing joiner usually needs to be sanded down to fit so the wing halves line up. Most directions suggest that you use 6 drops to secure hinges. I usually add much more, but no so much as to get it all over the place. Done that myself early on, but learned the hard way. Debonder will remove excess CA immediately if you catch it before it hardens. Many experienced builders make fun of ARF's, but there is definitely an art form to assembling an ARF so it's strong and clean.
I agree with Rcpilet. I usually add my own hardware. I have yet to see a hardware package that wasn't pure junk. I too wish the manufactures would listen to their customer base and add quality hardware. I would pay more for the model to get a good hardware package. IMHO
