problems with dle-30
Engine will not run past halve throttle. Idle is good. Have replaced all fuel lines. No leaks. Have had all the gas pros trying to adjust needle settings. No matter what I try nothing seems to work. Next I will replace the carb. Old carb had been rebuilt. Sent engine to Tower Hobbies and the said engine ran fine no problems. Still the engine will not run past halve throttle.
