Originally Posted by
BoomerSooner
Thanks for the info. Is it pretty sturdy as is? I was thinking maybe 1" steel pipe.
Much better idea. Maybe make a jig or if you have a drill press, angle the deck so it does a slight angle. I think the weight of the plane and pipe will compress the wood a tiny bit and it will flatten out. Plus, you'd rather a plane roll up against the wall than off the rack!
