Hi Matt
I have been following your build with interest. Lots of great information and ideas. I have a few questions if you don't mind.
How did you cut the foam wing and how did you allow for the rib thickness. I think you said you did it by hand but how did you achieve the accuracy needed to get square cuts.
What is the blue tape on the cut wing. What is it doing.
What glue did you use to attach the spar to the wing skin.
What glue did you use to tack glue the ribs
How did you attach the rib blanks to the cut core sections for sanding. Did you mark then cut the ribs with mininal sanding.
David
