RCU Forums - View Single Post - Rc101
Thread: Rc101
Old 12-13-2015 | 02:37 PM
jester_s1
Moderator
Yes, this is the airplane section, but I'll help you since I drive trucks too.
2s is 7.4v. 3s is 11.1v. 2s can take you a long way as you play with the gear ratios, and you'll definitely break fewer parts that way.
Going up in capacity also means going up in weight. I'll suggest you start with calculating the run time you're getting with the 5800 now and then deciding if you really need more. The heavier battery will hurt your handling, your speed and acceleration, and will make wrecks worse. In addition, the extra weight will mean it takes more power to run the truck, so you won't get as big a boost in driving time as the arithmetic says you should. I'd be a much bigger fan of sticking with the 5000-5800 (or even going a little lower) and just buying more of them.
If the truck didn't come with cooling fans for the ESC and motor, it probably doesn't need them. There are guys who run these trucks in off road races on 3s who push them much harder than you will outside bashing with it. If the power system can take that, it can take what you'll be doing.
