Okay, next question.
I am using the Himax 6330-210 Pro motor. I received the template for the back mounted motor mount from Mike at F3AU. It says Prolog on it but I am told that both the Prolog and Episode fuselages are very similar if not the same shape up front. My problem is it is not even very close to fitting inside the fuselage. Is there anyone still reading this thread that used this motor/mount assy that could shed some light on it for me. A photo or two of your mount. Are the two fuselages actually the same?
I have now made a cardboard template off of the template from F3A Unlimited that Mike sent me and am in the process of trimming it to make it fit, from there I will make a balsa replica of it and then the actual ply mount. Just wondering if anyone has some helpful tips or hints.
Kerry
