Yesterday I add first glass cloth on upper wing surface. I usually use 20 gr glass cloth and R&G epoxy resin. Results are always great...
I need few more days to finish this stage on wing. But, on some other smaller parts, glassing is done...
My Autoclave...
For glassing process I need four days. First day cloth is applied on first side. Next day, I sand down surplus and after that glass is applied on other part side.
Than gentle sanding of all surface and I add one more layer of resin on every side. Just epoxy resin. That layer fill all small gaps and other holes on glass cloth.
Again sanding and last step is applying gray filler.
When that filler sand with sand paper surface is like glass, smooth and glibly...
On surface prepare on this way, applying panel lines, rivets, dummy screws and all other details is without any problem Sure, before that, everything must wipe with cloth wet with alcohol.
That's all for today...
Regards
Mirce
