RE: OMP Edge
I cut the servo extensions in two, hooked the end to the servos, and soldered some servo wire to that, left the RX end of the extension off. After I had the wing on, pulled the wires, cut them to length, and soldered the RX end on. Probably can't get them back out, but I have enough slack to get to the servo end if I need to replace the servos.
