RCU Forums - View Single Post - Skymaster F-4
Thread: Skymaster F-4
Old 12-19-2015 | 10:11 AM
dubd's Avatar
dubd
The SM F-4 is very reliable and flies great. I've had two. The first has over 100 flights. The second has one irritating issue and that's the nose door cylinder. It needs to be moved for better leverage. Better to address this before your first flight, otherwise you'll be landing with the nose gear up. If you move the CG to the rear most range you'll have no problems with it.
