RCU Forums - View Single Post - Thinned out Epoxy question
Old 12-20-2015 | 06:00 PM
  #31
chuckk2
Originally Posted by tailskid
I know how to make 30 minute epoxy cure in 10-15 minutes! All you have to do is add some Micro balloons and try to glue two very large wing halves together in a small room! <g>
You don't have to add the micro balloons! Invariably, when using 30 minute epoxy on a wing it sets up faster than you want it to. The last go around I had with a P-47 wing - - -
The epoxy started seriously setting up as I was cleaning off the excess, at about 25 minutes! And, this was in a slightly cooler area than normal room temperature!
