RCU Forums - View Single Post - DA engine worth the extra price?
Old 12-21-2015 | 09:56 AM
Truckracer
My Feedback: (19)
Originally Posted by speedracerntrixie
Baffler, the DA ignition requires a minimum RPM in order to fire, the DLE does not. I suspect that if you retard the timing on your DLE a couple degrees by moving the sensor counter clockwise while looking at the engine from the front it will stop kicking back.
+1 on the timing.
The 55 shouldn't bite unless you really give it a limp wristed flip.
bafflerback, the Rcexl ignition used on the DLE does retard for starting but you have to flip the prop briskly to activate the retard. If flipped slowly, the ignition will fire with full advance (the static timing point).
