RCU Forums - View Single Post - RC Pane, info and value?
Old 12-23-2015 | 12:48 PM
SeaJay
Dynarider33..
I am not exactly sure what model of plane that is, but I can tell that it is a Basic trainer, and the engine that is mounted on it is an Evolution Alpha engine which I believe is a .46 size engine ( I have a couple of these engines, and they are easy to use, and run well). I see that there is a Spektrum sticker on the side of the plane, without actually knowing what transmitter is actually installed, I can't give much info on it, but since it is a basic trainer, with the basic engine, I will just guess that it has a basic transmiter..
Brand new, the plane would be about $100 - $120 for the ARF kit, the engine would be around $80, and the transmitter probably about $150, for a total of about $230 - $250 brand new, and if you are planning on trying to sell it, don't expect to see much more than half that, maybe $150 for plane, engine and transmitter. If there is a field box with starter, Glow igniter, Power panel, Fuel pump, etc. then you could possibly get about $200 for all of it.
My Recommendation to you is........... Register with the Academy Of Model Aeronautics (Modelaircraft.org) find a local club, get an instructor and learn to fly!!! Believe me, it's a lot of fun!! I have been flying for about 35 years now, and have about 40 +/- planes from small foamies up to 94" wing span aerobatic models, and still enjoy learning new things!! a warning tho, it should be classified as a disease, as once you are bitten with the RC flying bug, it's difficult to recover!!
I hope you take that plane and go fly it, and if you need advice or help, etc. there are lots of folks right here on RCU that are willing to give sage advice!!
Hope some of this helps, Craig!!
