RCU Forums - View Single Post - RC Pane, info and value?
Old 12-23-2015 | 05:31 PM
bikerbc
Dynarider33 I agree with SeaJay You will not get much for it if you sell it . You can tell its been sitting . The head bolts are rusty ..Have you tried to turn the prop or move the throtle back and forth ? If you can get it started you will need to check how old your batteries are and probably have them replaced before it is safe to fly . Its hard to say for sure but because it has been sitting for a long time in a shed the servo and switch connections could be corroded and need to be cleaned .Possibly replace the switch . So even if you decide to keep it and learn to fly it will cost you a few bucks . The plane its self is probably worth $100.00 if its in good shape . If its a 2.4 Spektrum radio system its worth a few dollars depending on how many channels it has and if it has been kept in a case etc . I would be inclined to keep it too . That is if you can get it started .
