Here is the view of the bottom of the wing panel from the tip rib, after cutting away the tabs. Note that if they are not perfectly flush, I left just a little bit of the tab material behind.
The next step is to sand any excess tab material -- and that of the wing bolt reinforcement block -- off, so that the bottom of the wing is properly contoured to the airfoil shape.
