RCU Forums - View Single Post - Saito FA62A Air Bleed adj.
Old 12-27-2015 | 06:29 PM
RBACONS
When set by the factory, the screw is just below the top of the plastic housing. This will be on the rich side, but that is what you want for the initial break in period. Just screw it back in until its a turn or so below the housing and you should be OK.
