You will need to make a little taller gear for it. Electric swing a lot bigger props. Run a 16x8 APC E prop. Will give you plenty of power. You can always drop down the diameter and raise the blade count. Run a 14x6 (4) blade too.
A motor like this
http://www.valuehobby.com/power-syst...-airplane.html
http://www.hobbypartz.com/96m606-big...030-400kv.html
Battery
http://www.valuehobby.com/power-syst...0mah-6s-t.html
ESC
http://www.valuehobby.com/power-syst...connector.html
http://www.hobbypartz.com/07e06-proton-60a.html
Buzz.
