Regarding the rudder servo set up guys, i recommend you cut further the wooden mount to allow the servo to come closer to the exit of fins skin.
This will allow you to use a closer hole on the servo arm to the servo gear providing better resolution of movement (maximum end points) and no loss of torque.The aileron servos can be elevated with a few washers too to achieve the same .
My 2c
