RCU Forums - View Single Post - Conquest 1 Bearcat
Old 12-29-2015 | 07:21 PM
  #34
tdstaf's Avatar
tdstaf
After getting all the spars in place I glued the wing skins that were prepared ahead of time to the spars from the center out with medium Ca.
Then I turn the wing over and glue the sheeting from the inside with thin ca working my way from the center of the rib to the out side using the bench to making sure the sheeting is firmly against the ribs.
When I finished with both wing halves I glued in the gear blocks with 30 min epoxy and let them set for the night.
ID:	2138482   Click image for larger version
ID:	2138483   Click image for larger version
ID:	2138484   Click image for larger version
ID:	2138485   Click image for larger version
