Originally Posted by
Lifer
I found mine to land better if using a 6" pitch prop. I'd start with the 17x6 and go from there.
The most important issue with the tires is to make sure they can't come into contact with the wheel pants. If they do you will nose it over and damage the plane.
Thanks. The stock tires have a ton of clearance, so sounds like they will be ok then.
