RCU Forums - View Single Post - Another Drone Pilot does it Again
Old 01-01-2016 | 09:34 AM
  #2776
franklin_m's Avatar
franklin_m
Originally Posted by AllModesR/C
I thought jet engines are designed to withstand geese being sucked into them? So how could a little drone be so "catastrophic?"
Had a sparrow hit my armored windshield at 500kts (EA6B at 500' AGL on a military training route) - completely shattered, nearly penetrated into cockpit. I can assure you that hitting a bird can quickly become a safety of flight emergency in an aircraft. Here's a few pics to see what birds can do:
Even if damage to engine is contained, you often lose redundant electrical and hydraulic systems due to compressor / turbine blades cutting lines etc. Leaking hydraulic fluid on hot section of engine often then leads to inflight fire.
I can only imagine what a 2lb quad full of metal motor casings and lipos would do.
ID:	2139025   Click image for larger version
ID:	2139026   Click image for larger version
ID:	2139027   Click image for larger version
ID:	2139028   Click image for larger version
ID:	2139029   Click image for larger version
ID:	2139030   Click image for larger version
