Earlier in the year I picked up a framed Kaos built from a Bridi Kit for a whopping 20.00. I immediately picked up a .61 FSR for it and then tucked them away for a couple months. After finishing a few other projects I pulled it out and began covering. I'm quite happy with the outcome. Truth be known it was an experiment on how well the color scheme was going to work as I plan to use the same scheme on a Reed Falcon. Unfortunately on initial run up it was discovered that the engine bearings are bad, will have to wait until the postman drops off the new set.
