Originally Posted by Sport_Pilot
Then again you can strap a bomb to it and kick it into a crowd! And it meets the definition of aircraft!
Rob2160
LOL, what definition of aircraft are you using? It doesn't meet the definition accepted by ICAO.
Aircraft*. Any machine that can derive support in the atmosphere from the reactions of the air other than the reactions of the air against the earth’s surface.
P
robably the only one that counts the FAA's.
Historically, the FAA has considered model aircraft to be aircraft that fall within thestatutory and regulatory
definitions of an aircraft, as they are contrivances or devices thatare “invented, used, or designed to navigate, or fly in, the air.”
I'd say that a football having a pointy end on each end and it is contrivances or devices that are “invented, used, or designed to navigate, or fly in, the air.” indeed meets the FAA's definitions of an aircraft, Of course that may only be in the Northern Hemisphere. Where the FAA makes up it's own definitions.
