Originally Posted by
Rob2160
LOL, what definition of aircraft are you using? It doesn't meet the definition accepted by ICAO.
Aircraft*. Any machine that can derive support in the atmosphere from the reactions of the air other than the reactions of the air against the earth’s surface.
FAA says it is any device designed to fly in the air, ballons and model airplanes are aircraft to them. So a football does fly though the air and is an aircraft. If you don't agree then maybe the FAA should instead require Frisbee's to be registered. I bet someone could attach a radio to one as well.
